Re: I phone 5 won't hold charge and should the battery icon in upper corner be white never s.w that
It will show a lighting bolt beside the battery icon when charging you will hear a sound if enabled when you plug it in
Green is for fully charged
You can enable the percentage by going to Settings>General>Usage and tap to turn on battery percentage that will show you how much charge you have left
I phone 5 won't hold charge and should the battery icon in upper corner be wh...
It's green only when on the phone is charging. As far as your battery not holding a charge you need to take your phone to the nearest apple store so that they can give you a new one.
