What can cause a reception problem after replacing the iPhone 4s battery?
I
iMore Question
what can cause reception problem after replacing iphone 4s battay?
the iphone get on/off reception, can be 1-2 min with good reception and then 1-2 min with no reception at all.
allready tried replacing the antena and the battary, the connection of the battary and the antenna to the motherboard looks undamaged/
Ariel Babalao
830
Re: what can cause reception problem after replacing iphone 4s battay?
Since you removing the battery often, did you set back the time to today's date? It could well be the reason why you are loosing signals.
smitty22d2
