Will setting a notification at a place drain battery?
SaMaster14
Mar 8, 2012
910
18
Well, I set a notification for when I arrive back home for thanksgiving break and I was just wondering if having that notification searching for location in the background drain my battery/use a bunch of data.
Thanks guys
e koulak
Nov 7, 2012
23
I have done this in the past and it does affect the battery a little but at least in my case it was so minimal, it wasn't worth concerning my self about
iLive an iLife
Feb 27, 2011
1,087
32
Thanks guys
Location based reminders definitely affect battery, but it varies. As in the one poster, it was minimal, but I've had it significantly affect my battery life. My office had poor reception to begin with, combine that with a constant ping for GPS and I was losing a ridiculous amount of battery per hour (10-20%).
jerome g
Oct 26, 2010
210
If my thinking is correct, It can definitely put a big drain on your battery, as location services must be on.
Peligro911
Jun 1, 2011
5,883
136
I think that feature is made for a shorter time frame like a event on the same day vs weeks later
It might be better to set a reminder in the calendar or something vs using that
SaMaster14
Mar 8, 2012
910
18
I set the reminder for something I need to do tomorrow.
Regardless, I've had it on for over a day now and I don't see much battery drain. I'm also almost always connected to WiFi in my dorm and throughout campus though.
