Not too long ago we was upgraded to BT infinity, And you sure can notice better speeds on all devices, But shortly after, My iPhone 5s (The only iPhone in the house) keeps getting really low signals, This only happens to my phone and nothing else (Android phones, Computers etc)
The way I can notice is I play 2 main games which are clash of clans and 8 Ball pool, Clash of clans will randomly pop up with a wifi symbol meaning my signal is low, Meaning anything I do wont be saved and I have to close and restart the app again, Sometimes that wont even solve it, And 8 ball pool it will say connection is slow and cut me out the game, I downloaded another game to check and that did the same too, Sometimes safari is even really slow.
I have reset all settings on my phone, I have changed channels on my hub and nothing has helped,
Any other suggestions on how to fix this as it is highly annoying!
One more thing, I can go on someone elses wifi and it will work perfectly fine, I can even create a hotspot on my PC using the same internet connection and that will work fine, And the wifi symbol in the corner wont drop to one bar, It always stays full or one bar down, I just dont understand it!
Hope you can help
Hope you can help
