Why is my battery percentage drain so fast?
I
iMore Question
why is my battery percentage lies and why it drains so fast ,
my battery was just about 42 percent , but after a few minutes , the percentage was 1 percent , but after i put my charger back and it appears the true battery life percentage.
Rob Phillips
Champion
May 1, 2012
13,761
Welcome to iMore! You could try recalibrating your battery, which ensures that your battery and device are on the same page regarding your battery percentage.
1. Charge your device to 100%
2. Unplug it and then use your device until it shuts itself off (runs out of battery)
3. Recharge to 100% with no interruption in charging.
It may or may not help but it's worth a try. What device are you using? If it's an older model your battery might just be nearing the end of its useful life. Apple's iPhone batteries, for example, are designed to retain 80% of their original capacity for 500 full charge cycles. After that you're on borrowed time.
