Why does the battery drain so fast?
I
iMore Question
why does the battery drain so fast
I'm constantly charging this phone and it is very discerning because I don't have chargers everywhere I go. It seems like you can only use it for maybe a couple hours and you have to charge it again!
nikkisharif
Jun 2, 2011
8,563
42
48
Re: why does the battery drain so fast
What phone are you referring to? If you recently updated it, you might need to do a clean install. Sometimes you get a bad install with updates and have to do it over again.
HAWK
1,108
Is it a new phone and you are playing on it non stop cause it's new? I know personally if I am on my 6 for 3 or four hours solid downloading and whatever else it needs a plug in... But that's not "normal" use
Premium1
Trusted Member
Aug 17, 2011
3,610
43
That's true. Apple never goes big on batteries, so if you're a heavy user it won't last long.
Telespielstube
Oct 16, 2014
42
Nobody will ne Anke to help you if you don't give them more informations about your phone, the apps you are using, a screenshot of the "Battery Usage" screen.
knighty2112
85
I get 2.5 to 3 days from a full charge on my IPhone 6+, so whilst earlier iPhones were notorious for been wallhuggers that is no longer the case, at least for the 6+ anyway.
Premium1
Trusted Member
Aug 17, 2011
3,610
43
You're not a heavy user then. And even so, they only finally got a semi decent battery with their phablet.
knighty2112
85
If I use the phone heavily by watching Netflix movies or when I used to play Plants vs Zombies heavily on it I still managed to get over a days use on it with all my other normal days usage added on to it too, so the 6+ does have a much longer battery life than all previous IPhones.
ultimate4799
