Why does my iPhone 5S drain battery?
I
iMore Question
Hey there guys, yesterday I jailbroke my iPhone 5S with iOS 8.4, I installed some tweaks and now my battery drains like 2% per minute or more when using LTE or 3G, it also overheats a lot. Here is a list of my tweaks, could you tell me which one causes the problem?
Barrel
CameraTweak 3
CCBackground
DetailedBatteryUsage
iFile
iCleaner Pro
Instagram ++
Lithium
NoSlowAnimations
Phantom For Snapchat
Spin
StatusVol 2
Zeppelin
3G Unrestrictor
60,461
915
Your best bet may be to uninstall the tweaks, test your battery's performance, and then reinstall each tweak while examining the battery drainage in between installing each tweak.
HankAZ
Banned
Jul 26, 2012
6,092
Understanding that the whole jailbreak is a kludge at best - and it's invoked by exploiting a vulnerability in iOS, it's really a wonder it works at all. With that being said, however, each JB app could easily be causing your issues. As D said, your only option to find/fix the cause of your issue would be to back them all off and install them one at a time, testing extensively after each app is added.
Jethro7
