Why do I have low speaker volume after El Capitan upgrade?
I
iMore Question
Low speaker volume after El Capitan upgrade
Has anybody experienced low speaker volume after upgrading to El Capitan? My speaker volume was working well but since the upgrade I've had to up the volume to max on everything yet it still sounds like if I had it at half or below. I am on macbook pro mid-2012.
Laelipoo
2,206
66
Re: Low speaker volume after El Capitan upgrade
Have you gone into System Preferences -> Sound to make sure nothing is turned down?
Jaguarr40
14,306
14
Hi! Yes, I checked that first and tried to do a search before posting.
Thanks!
I have an early 2015 MBA with EL Capitan with no volume issues at all and I would recheck the output and input settings for sound in Sys pref and make sure the output settings are as they should be at max.
Mohammadreza
