While I am asleep I get NO text sound notifications with volume on High. DND is NOT on. What can I do?
I
iMore Question
This only happens when I am asleep and the phone is no in use by me. I have an iPhone 6s and I always update. Do not disturb is not turned on.
Ledsteplin
Oct 2, 2013
51,092
846
108
While I am asleep I get NO text sound notifications with volume on High. DND ...
There's no reason why this would only happen while you're asleep, unless DND is on or your device is powered off. How would your phone know if you're asleep or not? What, exactly, happens?
Inkbuddy
Dec 21, 2015
I have the same problem and it doesn't matter if the phone is sitting on the counter not being used or if I am actively using it to send messages. I get no sound and no vibration at all when I receive a message and it doesn't matter if it's SMS or from another iPhone user. The DO NOT DISTURB is not turned on, I've tried a reboot, I've tried different tones and vibration settings. I've tried a reset of General/Reset/Reset Network Settings
Incoming messages give no notifications at all.
doogald
Trusted Member
Oct 23, 2012
2,803
153
63
Is this all of the time or just while you are sleeping, as the OP asked? If it is all of the time, have you looked in settings / notifications, under Messages, to ensure that allow notifications is turned on, sounds are turned on, etc.?
anon(5841099)
Oct 27, 2014
4
This is happening to me as well. I notice it mostly with WhatsApp messages because it's my main form of communication with lots of my friends. And it will sometimes show the message on the lockscreen and light up the screen without making a sound or vibrating. No ringer on silent, no DND.
Seems to happen a lot since 9.2, maybe a bug?
60,414
884
I'm not buying it. Sorry. There is no way the iPhone knows when you're "sleeping" and you did state that "this only happens when I am asleep..." That tells me that if you decided to take a nap, you will automatically not receive any text notifications. Impossible, unless you:
1. Tell everyone you know not to text you
2. Initiate the Do Not Disturb feature.
3. Enable the mute switch.
4. Turn the volume all the way down.
5. Enable airplane mode.
6. Pair your iPhone with an Watch with notifications muted.
7. Power the iPhone off.
doogald
Trusted Member
Oct 23, 2012
2,803
153
63
Re: While I am asleep I get NO text sound notifications with volume on High. DND ...
8. Were asleep and the sound wasn't loud enough to wake you.
Jamescunni
Oct 29, 2015
Same here got no volume on any media even though sound is on full on videos I have to press volume button for sound to play even though it's already on full tried a wipe still same afterwards I do get vibrate though
Mohammadreza
