Don't know if imessage is something new with the ios5 or what? What's the difference between imessage and text/emailing?
so u need wifi to have it work? you can't use 3G?
will automatically list the people who have iOS 5 in your contact list or will you have to ask around and manually add those by say asking them for a PIN# or similar ID Code?
You just fire off a message to anyone you like using the normal Message app and if the recipient has iMessage it will automatically switch to an iMessage. No need to do anything. No PIN required.
Oh cool so it won't be a separate app, now that's convenient
question: what is imessage and how do i get it? is it supposed to be preinstalled with the ios 5? cuz i dont see it?
I hope that it will have groups/group messaging added at a later date. That was one thing I loved about BBM, and definitely would love to see that on iMessage.
As stated before it will run over data, so if you're connected to wifi when you have no cellular service, it will work. Not every iPad has a cellular connection, and of course the iPod touch doesn't.
