- May 15, 2010
- 208
- 7
- 0
I pulled out the SIM card and used an LED flashlight to look into the slot towards the screen side and the 3 white dots are visible, but I do not see any red indicator.
I'm wondering how obvious or clear it would be to see if the indicator actually turned red? Is it located just inside the SIM card slot or is it very deep inside the slot?
Mine fell out of my pocket and fell into the pool (<3 feet deep, kiddie wading pool). I shook it and turned it off for 3 days to dry out and tried the restore&set up-as-new, but no luck (error code 4013).
I'm taking it into the Apple Store and hoping I can get a replacement, but wanted to check for myself before going in whether the water damage indicator was actually tripped.
Any feedback would be greatly appreciated. Thanks in advance!
