I
iMore Question
So, I have this iPhone 4s, which was broken. So i replaced the screen. While I was replacing it, I accidentally broke the black wire that connects the battery to the motherboard. So I dont know if it works, and I dont want to spend money on new battery if the screen doesn't work. I also want to test the motherboard, since I replaced the screen because the old one showed blue vertical lines. So I need to be sure both screen and motherboard is functioning. Can you test it somehow without battery?
