SSH iphone connection problem
jxj988
Apr 4, 2010
9
Hey guys,
i have iphone 2G firmware 3.2.1 . before i updated i used to SSH using cuteftp with no problems. but after the update and the jailbroke with blackra1n i installed openssh and SBSettings to activate ssh and tried to connect using cuteftp with original pass and user but no luck ... i even tried to use WinSCP and it didnt work
it's like the iphone rejects it ..
any ideas are appreciated.
THANKS A LOT :)
Allyson Kazmucha
1,022
75
are you making sure you are on port 22? also, this should be in the jailbreak forum, not the general iPhone forum.
also, try cyberduck or fugu. cuteftp kind of sucks. i'm assuming you meant 3.1.2 as well.
Allyson Kazmucha
1,022
75
ya 3.1.2 mistype thanks ..
I only ever had that happen to me once... and I think I determined something went wrong w/ the jailbreak, because I restored and re-jailbroke and it worked. That may be your only option if you know you are doing everything correctly.
Blin
