Siri and activate Bluetooth or WiFi Problems
Rockdog97
1,514
22
Has anyone been able to get these commands to work?
I'm on 6.1 and cant seem to get Siri to activate bluetooth or turn wifi on/off...
kch50428
21,025
305
Without jailbreaking, I can't find anywhere that says Siri can do any of the things you speak of...
yet...
Rockdog97
1,514
22
I have that app already installed, but cannot seem to find where to set this up.
I went into Cydia and 'reinstalled' it but I can't seem to find any settings - or is this a behind the scenes app?
Rockdog97
1,514
22
is SiriToggles compatible with iOS6.1? because i have it installed and the simple commands such as "turn on bluetooth" or "turn off wifi" do not work.
patricksmangan
287
11
Hmm, I guess it hasn't been updated. I had it installed but I don't use Siri that much, & yeah it's a tweak so its not an app. You should email the dev, maybe he or she will get it working with an update.
Arvhan
Mar 1, 2013
i4s OS updated to 6.1 and since then wi-fi is not working (can't do any thing with ON/OFF selection), any suggestion to solve the problem?
At present can't do surfing.
Thx
Arvhan
Mar 1, 2013
My i4s wi-fi was not able to find any net work.Then I updated the OS to 6.1 and problem became worse, now can't do anything with wi-fi ON/OFF slection. It simply doesn't allow to to anything with wi-fi, something strange!!!!!
Anybody has same problem? Need help.
Apple care advised me to replace the phone ($ 199 + Tx ). ???
