Simple cleaning tips for polyurethane Smart Cover !
Donkichot
575
I bought the iPad Pro 10.5 and I have sold my iPad Pro 9.7 with the Smart Cover because it now can not fit the new 10.5 iPad Pro.
So my Smart Cover 9.7 was a bit dirty and have all sort of marking on it after more than a year of use...
I decided I must try to wash it... but how ...? After searching the net for solution, none where acceptable for me so, I remember cleaning my Silver body of my MacBook Pro with Mr. Clean White Magic Eraser with great result, so why not try this on the Smart Cover...
Wow it work perfectly! No water needed, just swipe gently always in the same direction from left to right and man it's like new !!!
I regret not taking before/after picture...
Now this tips is for the outside of the polyurethane Smart Cover, anyone have a tip for cleaning the inside ?
TurboTiger
2,773
10
I have used a Germ-Ex wipe everyday for several years on the inside & outside of the Smart Cover with out any issues.
I spend a lot of time in a cigar lounge daily & the cover absorbs the smell.
Good Luck
developer_black_code
