Restore/Recover Jailbroken iPhone problem Restore/Recover Jailbroken iPhone problem
Filmgeek#IM
Mar 6, 2009
I recently jalibroke/unlocked my 1st Gen iPhone with 2.21 firmware - and made the same mistake as post - 168354 (can't link to it - I'm too much of a noob here.)
Basically, I chose from the "general" app to Reset all Settings - (the one that takes around an hour).
Now when I restart it just gets stuck with the apple/pineapple screen and the iPhone won't show up in iTunes (so I can restore the modded firmware.)
I can't seem to get it into DFU mode - when I release the power button, I get russian Steve Jobs.
Any help would be greatly appreciated.
10.5.6 (with the iousbfamily315.4.1 installed) iTunes 8.1
TIA
Voltaic Shock
81
This is a pain (been there done that).
It will take you a few tries to get it into DFU mode. I spent an hour trying to get it working. You need to try to get it into that mode and then plug it into the computer as fast as you can. This is what I had to do.
Filmgeek#IM
Mar 6, 2009
Still failing to get it in DFU mode. If the phone is on it's got the pineapple logo up...and just constantly restarts.
If I try to get into DFU while the logo is up...it shuts off the phone.
If I try to do it at startup...I get nothing (or the Russian Steve Jobs.)
Fmrnyer32
Apr 1, 2009
18
same issue happened to me, i restored the phone back to original box content and then once i restored it, i then jail broke it again and it took....took me a little bit longer but got it to jailbreak!
bloodfest30
Apr 27, 2009
10
Well I have this same issue, though my computer won't recognize my iPod when plugged in. And it just constantly restarts.
I have the latest iTunes (8.8.1?), and yes my ipod is plugged in correctly.
MrWorried
Jul 2, 2009
Bricked iPhone... with damn Pineapple & Steve Jobs (in Russian)... cannot DFU at all
I was given this phone and I thought it would be an easy task to fix it! Hell no! I've spent hours.... to no avail. The phone cannot be DFU'd at all! It can be turned off by pressing the power button and the home button, but the phone will not be recognized by the computerS. I have tried it in 3 diff. computers already. Argh! Does anyone have any ideas on how to fix this??
Thanks.
Jedi
Sep 2, 2008
36
Uninstall iTunes and then reinstall it.
Just checking you're putting your iPhone into DFU mode properly - hold power for three seconds, keep hold of power and press home for 10 seconds, release power and keep home pressed for up to 30 seconds or until your computer recognises a new device.
vber
