Random super fast battery drain
c23rainman
Mar 7, 2011
9
So this morning I took my phone off the charger at 100% when I woke up. Within 15 minutes of limited Internet use, I was down to 96% and its been fading fast. Barely any use and I'm down to 88% just 2 hours later. Usually it takes much longer to drain. Just typing this post has dropped it by 2%.
Anyone else experience this, and what should I do? I don't think I changed any of my settings between yesterday and today. It's really strange.
ThePinkChameleon
Trusted Member
Jul 8, 2011
10,857
475
83
Have you loaded up a new app since this started, which could be the culprit? You could try to reset all settings AND reset network settings - this may help. The only thing is after you do both, you will have to reset your ringtones, etc. and put in your wifi info again as well. all of your data will STAY intact - nothing as far as that goes will be lost. Some people ask and get concerned about it, so in case you didn't know thats why i wanted to mention it. :)
FMHPro
