I have no signal at my house, I run off wifi. Is there a way to turn off the 3G signal is its not searching for one? My battery seems to drain quickly at home
You can do airplane mode and then just turn on the wifi toggle... That should get what you're looking forThere's no way to turn off 3G but leave on wifi?
No problem... Glad you got what you were looking forThat worked!! You actually have to go into wifi after you turn on airplane mode! Thanks![]()
