Problem with iTunes
iPetar
Aug 21, 2015
I can't open iTunes on my iPhone 6. I can enter and download from app store but when i want to listen music or if I try to open iTunes it just won't open. If I click on icons iTunes it's just open iTunes U and nothing else.
Pleas I need a help.
Ledsteplin
Oct 2, 2013
51,092
846
108
Did the hard reset (reboot) work? If not, try Reset All Settings.
Reset All Settings
Go to Settings >General >Reset >Reset All Settings. This resets to default everything in Settings, including notifications, alerts, brightness, and clock settings like wake up alarms.
That don't work, you may need to restore as new.
Ledsteplin
Oct 2, 2013
51,092
846
108
When I launch iTunes app I received message "cannot connect to iTunes Store".
1. Are you logged in to the iTunes Store?
2. It may be a signal issue. Do you have a strong wifi /cellular signal?
3. Try a reboot again. A hard reset.
Hold the top or side power/sleep button and the home button at the same time until the Apple logo appears, then release.
Sometimes it takes more than once.
iPetar
Aug 21, 2015
Can not connect to ITunes store.
Still having problem.
No members online now.
Mohammadreza
