Problem with bite sms please help!!!!!!!!
vnevsky
Oct 17, 2012
I am having an issue with BITE SMS app in Cydia.............on my screen there is an exlamation point like an error on the app (just like the post icon) and I keep thinking I have a new message and its a little irritating......
I tried uninstalling and reinstalling but no luck...............
Any suggestions on what I can do and how to get rid of this?
Massie
5,063
332
83
Open the app and go through all your conversations, looking for the exclamation point--it usually means you have an unsent message that didn't go through. If you don't find it, simply start deleting conversations...there was a bug with some bite installations where you had to erase your conversations after the first install to get rid of that, but once gone it didn't come back.
Sharma15
424
23
Don't delete convos. There's a setting to fix this it removes the red "!" From the app icon. Look in the settings it'll probably be under more settings or extra settings.
flickoo
