Problem with 4.2.8
bub_33
Jan 28, 2011
21
I have noticed since updating that my reception has gotten really worse. Also, my battery life has gone way down. I could go a full day and be around 50%, now half way through the day I have to charge because I am at 20%. Anyone else have problems with the update?:mad:
FortyTilFive
May 11, 2011
Same Problem
I just got my Verizon iPhone with 4.2.8 and am having the EXACT same problem...I would also love to know if a lot of people are having this problem and if they are.....WHAT DO I DO?????????
iRooney
103
Are you Jailbroken? If so what apps are you running. I haven't noticed any kind of a hit on battery life. In fact, it seems much better.
ZOFOURTWENTY
721
9
not experienced either of these 2 issues, try updating your PRL by dialing *228, my battery life has actually improved since updating to 4.2.8
Blackbelt
51
6
Nothing different were noticed . My wife and i have our IP upgraded to 4.2. 8 the upgrade took about fifteen minutes for our two IP4.
Alveezy
73
4
my update went well and i believe that my battery has been better since the update. this update is supposedly getting rid of the "locationgate" issue. it shouldn't log any of your location coordinates anymore so that's a plus. the main-problem that people are running into when they update is that they restore from back-up. restoring from back-up causes battery issues period.
munchkinsdad
127
8
I heard that if you do a verizon iphone system update it takes care of that...
in fact, I did that and BAM! back to normal!!!
*228 thing...
worked for me! and if it works for you follow @Cnergey . he hooked me up on it!
rdrum
155
I use my phone A LOT for streaming radio, video, twitter and so forth, so I am generally mindful of battery management. I haven't seen a battery impact after the update. It certainly hasn't gotten any worse (that's something that I would notice right away, of course).
I haven't had any signal degredation either.
coltsbr
519
31
I have had much better battery life. I have been getting 2 days out of my battery since the update. :D
beto89
66
I havent had any battery life problems, but I have noticed that my reception goes to "o" more often now, *228 didnt help. Jailbroken on 4.2.8, I might try restoring as new and starting over.
anon4705295
504
39
Aghhh I've been getting that too! Lately I only have 3G about half the time... and I'm on 4.2.7 :mad:
dmt316
497
9
I'm still on 4.2.6 and get the o a lot. Wtf does the o mean????????
Alveezy
73
4
Actually, 3G = EVDO. When you see the "o" - that means 1X.
1X would be the equivalent to AT&T's Edge speeds. i tried resetting my network settings and it somehow fix the 3G problem from going to "o". i don't suggest those that are jailbroken with greenpois0n to do this because it might leave your phone in a spinning wheel loop.
sunnyville01
