Post battery screenshots 5.0.1
v1nn1e
202
18
Don't mean to double post or anything -- but just thought I'd let you guys know that I posted about my awful battery life post-5.0.1 in the Apple forums, and just got a call back from someone at AppleCare. They appear to be hot on the case!
Tpence2177
Trusted Member
Nov 2, 2011
792
Mine can definitely drain fast. This was with 12 hours at work where I didn't use it much though. I'd monitor it and take some screen shots then go to the apple store and show them your usage vs battery drain and see if they think it's within "normal" limits.
Sent from my iPhone 4 using Tapatalk
LSglock89
439
11
I know if I'm not on wifi this thing dies within 7 hours of little use. I'm going to start taking screenshots to document it. The closest apple store is a solid hour and a half drive.
ame
Trusted Member
Feb 17, 2011
1,872
31
48
I took this thing when I just connected to sync and update my apps like skype. I remembered to do it before it reset anything. I plugged it in at 17%. I generally get about 3 days.
precon22
237
her is mine not bad, it wierd i did a restore didnt help i did a delete complete iphone from my phone helped ALOT!!!
precon22
237
why is that ? that is with heavy usage and very poor reception, the wifi wasnt on till i got home and had 6 percent battery left ?
LSglock89
439
11
In comparison to others posted...some people are getting a full day on standby. It all does depend on usage, I agree there and whether or not you are on wifi or 3G.
Peligro911
5,878
136
All this makes u wonder if how did apple get there numbers did they actual test them ? Funny thing is my wife's iPhone 4 on same iOS 5.0.1 lasts way longer than my 4s
LSglock89
439
11
have you tried out the other terrible smartphones out there? I mean give me a break he made a day easy the evo cant even make it to lunch
Yeah, I've owned a couple BlackBerry's. Just odd the vast differences some people are posting.
Jethro7
