This my first time to jailbreak and all went well. I first used jailbreakme but kept having issue so did hard reset then used redsnow and works great.
The issue is my 3g toggle option in settings has changed to "Cellular Data" on/off.. After installing SBsettings the toggle for 3g will not stay on. It does say 3g on my status bar
Installed
My3g
PDAnet
sbsettings
After I first jailbroke the toggle in sbsettings for 3g woirked perfectly but after a bit (not sure if after something else installed) it wouldnt stay on. Every time I open the sbsettings the 3g toggle is red, I click it and it becomes green then close screen to reopen to red toggle.. I also installed voiceactivator and set it up to toggle 3g on and off but everytime I toggle it it say 3g enabled like it was stays off...
I have done several comeplete resets to try to fix and after the reset (complete reset to factory) the 3g option in the settings still is missing..
Is there anyting I can try to correct this?
Installed
My3g
PDAnet
sbsettings
