On my iPhone 6 the battery is discharging at a rapid rate. When I click on battery
I
iMore Question
it shows that the Home and Lock Screen used up 83% during the past 24 hours. I've gone in circles following instructions for making sure the Home Button is not stuck and was able to find another home button and I got it to open and show six choices and the one on the bottom said HOME which I was told to press and I did. Then this little round shadowy circle appeared on the screen. I then back to settings and clicked on The CONTROL CENTER and the next window showed ACCESS ON LOCK SCREEN and ACCESS WITHIN APPS; Both were on (green). Shall I leave them on?
MY PHONE WENT HAYWIRE AFTER UPDATING. THINK I'LL NEVER UPDATE AGAIN.
Please help, I'll be grateful FOREVER
nikkisharif
Jun 2, 2011
8,607
97
48
Go to settings > general > background app refresh & turn off the apps you don't need running behind the scenes. You can also check notifications & location settings. No need to freak out & not take anymore updates. Sometimes updating resets those settings. You also probably want to change your screen brightness to auto. Good luck
poplolzz
