Need help please!!!! 2011 mbp
Julie Waters
Mar 17, 2016
7
My MBP 2011 will not start up properly. I updated the software, as was suggested, and ever since then when I turn it on I get a gray screen with the circle and line through it then it goes to my utilities screen and says something about my hard drive not being mounted. I've followed the diagnostic suggestions that I felt comfortable doing, since I'm not very computer savvy, and no luck. Can anyone help please?!
OZsMac
377
12
18
Rather sounds like your HDD might be failed/failing. If you can manage to complete the tasks here, https://support.apple.com/en-au/HT201257, this will run a hardware test and show you what the issue might be.
I'm afraid that a trip to your Genius Bar or other PC repair shop might be in your future. The one bit of good news, the HDD is replaceable in the 2011 MacBook Pro, so a repair might not be that expensive (if you are planning to keep the machine for a few more years, make sure you put an SSD in it).
Good luck and let us know how you get on.
psamo
61
But it worked before the update right !.. I think it's not hardware failure.It may be a software crash.May be a format can help you.
Mohammadreza
