MBP 16" Power Adapters?
iRandyTX
Nov 17, 2021
Which power adapters work with the new 16" MBP?
So I have the new 2021 16" MBP that comes with the new 140w Power Adapter. I know that the 140w power adapter is the only one that will "Fast Charge", but when I'm sitting at my desk I don't really need that. I can save that adapter for when I'm traveling.
Also, buying a separate 140w power adapter right now is impossible. They're not available as a separate purchase due to stock issues.
So my question is which other power adapters can I use to charge my 16" MBP normally?
imwjl
1,399
12
Re: MBP 16" Power Adapters?
I can't speak for the 16", but found my old 29 watt and wife's or an Air's 30 watt charged the higher core SoC but at slower rate. I left the big brick at home and carried the little one to my work sites.
Annie_M
Mar 2, 2016
21,921
773
Hello and welcome to iMore! I'm sure that you will find the help you're looking for. When you get a chance, please take a minute to introduce yourself here!
Also, as an FYI: I have merged the two threads and deleted a duplicate post.
Annie_M
Mar 2, 2016
21,921
773
Thanks Annie! I couldn't find a way to merge the posts, or delete the duplicate myself.
No problem!!! :D If you ever have an issue that you need help with, just click the triangle with the ! mark in it. That will help you to report the issue and all Moderators are notified, and someone should respond quickly!
Gokox
