Macbook Pro 15" Mid 2015 i7 2,5GHz Radeon R9 - power consumption in idle
Igor Adamiak
Feb 28, 2017
My computer consumes approx. 30W at idle - is it not to much?
Battery enough only for 3h. :(
Someone can check this in own computer with similar configuration by coconutBattery for example? (with power supply not connected, "Discharging with" parameter)
Thank you.
59,647
618
Since Apple's website states that it could get up to 9 hours, depending on the usage, make a Genius Bar appointment with the nearest Apple Store to have them check it out for you.
Snoweagle
654
Thank you.
Using the same MBP and also coconutBattery. Currently mine's discharging with: 9.42 watts, running off battery power.
Ddearman0113
