I
iMore Question
Macbook Pro 13 Retina (mid 2014) battery problems
Hello Everyone
My Macbook Pro 13" retina (mid 2014) only powers up when plugged in and immediately shuts down if unplugged...I had it looked at by an apple service provider who discovered that the Logic board was defective and replaced it.....unfortunately though the battery issue is still the same. the battery was showing 68% a couple of months ago and has been dropping and now stands at 27%..I would like to replace the battery although I am worried that there may be another issue that is causing this problem.
My question is what other parts could affect the battery. I do not want to pay 800 to replace the whole upper case since my mac is already out of warranty.
Thank you
Battery Information:
Model Information:
Serial Number: C01445101PHFT60AL
Manufacturer: DP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 702
Hardware Revision: 000a
Cell Revision: 379
Charge Information:
Charge Remaining (mAh): 1581
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 5945
Health Information:
Cycle Count: 190
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 11295
MacBook Pro with Retina display, OS X Yosemite (10.10.4)
Hello Everyone
Thank you
Model Information:
Manufacturer: DP
Pack Lot Code: 0
PCB Lot Code: 0
Cell Revision: 379
Charge Information:
Fully Charged: No
Charging: No
Health Information:
Cycle Count: 190
Amperage (mA): 0
Voltage (mV): 11295
