Loose Mute switch on iPhone 11 pro max
aniss.kais
Oct 5, 2017
27
Hi,
I just noticed that my iPhone 11 Pro Max’s mute switch is a bit loose when it’s off., when the mute switch is _not_ engaged, it’s slightly loose. When I engage the mute switch, it’s locked tight, so I am a little concerned with this side to side play. The switch still works fine and I currently have no functional issues with it, but my concern is that it’ll get looser over time and cause malfunction. Is anyone else experiencing this issue with your iPhone 11/11 Pro/11 Pro Max?
aniss.kais
Oct 5, 2017
27
I bought my iPhone in France. and where I live there is no apple store. I wanted to know if others have encountered this kind of issue
pkcable
Q&A Team Leader, VR Expert
Jun 16, 2009
5,827
28
I don't believe you are the only one. I found a thread about this same issue at another iPhone (Mac) fan site.
Ledsteplin
Oct 2, 2013
51,092
846
108
Is there a reputable repair shop in your area? It may just be loose screws. I wouldn't think it would cost much to fix.
Mohammadreza
