Left AirPod Losing Battery Significantly Quicker than Right One
SaMaster14
925
14
18
This has happened twice in a row now, so I decided to document it.
Each time, the AirPod case and both AirPods were (according to my phone) both fully charged at 100%
Went for a workout and started using my AirPods as normal. The first time, I started losing sound in the left ear and when I checked, right AirPod had 90% and left AirPod was at 1%!
The second time (today), the results weren’t as drastic, but the left AirPod was clearly draining battery quicker. Here are some screenshots showing today’s battery percentage (and passage of time based on the time of screenshots)
I have no idea if the problem is with the left AirPod, or the case not charging it properly (and displaying a false positive that it is fully charged).
Any thoughts?
mogelijk
iPad Champion
Champion
Jan 25, 2014
1,137
4
//uploads.tapatalk-cdn.com/20181029/948cea4feea91c6805a6ea08399e875f.jpg//uploads.tapatalk-cdn.com/20181029/2ed2e38d4fb50d1cfe7b4b509b655036.jpg//uploads.tapatalk-cdn.com/20181029/49b052f2b2a885a386d990b5f8ee1b56.jpg
Any thoughts?
If you have an Apple Store close, I'd likely take it in to the Genius bar. They may find there is some type of lint that is preventing the Airpod from charging correctly and, if it is a battery issue, can give you a quote to replace the Airpod/battery (if no longer under warranty).
I'd say check for some lint yourself but I'm going to assume you've tried already.
SaMaster14
925
14
18
I will inspect further regarding the lint, I thought I had cleaned it properly, but if it continues to happen I’ll take them to Apple!
Thanks!
mogelijk
iPad Champion
Champion
Jan 25, 2014
1,137
4
Thanks!
Yes, an advantage the Apple Store will have, they have experience in knowing the nooks and crannies where lint might be hiding.
Mohammadreza
