itunes sync problem - need advice
sameer kapoor
55
When I connect to itunes after some time it says " iphone could not be synced because sync session failed to start " what does it means . I have MiPhone* 4 untethered 5.0.1 . Thanks in advance.
* before jb its iPhone after jb its MiPhone
sameer kapoor
55
No , it is set to sync to computer , I can't understand the reason behind this problem , should I restore to itunes ? However I used itunes to restore or update purposes only otherwise I don't use it.
Highrisedrifter
2,999
I had the same issue and it was because iTunes had not installed some of the USB drivers for my phone that were required in order to start the sync. I uninstalled and reinstalled iTunes and everything was fine. Hope you get it sorted.
iDonev
876
35
I've had the same problem. Resolved it the same way.
No members online now.
INTERNET BUNDLE NOW
