Is there a way to switch a phone straight to airplane mode when you turn it on?
I
iMore Question
I switched my phone off during an argument and I don't want to receive the messages yet that might have been sent since, but need to use it for my alarm clock! Is there a way to switch it straight to airplane mode when i turn it on, its whatsapp so as soon as i ge them the other person will know they're received.
Ledsteplin
Oct 2, 2013
51,092
844
108
Otherwise, the best you can do is power on, pull the control center up, and turn on airplane mode..
Tartarus
Feb 20, 2014
17,446
26
48
Safest way to do this is to pull out your SIM card of your iPhone and switch off your wifi router. That way your iPhone won't be able to connect to internet and you can safely start the iPhone up, put it in Airplane Mode and put the SIM card in and switch on your wifi router.
Ledsteplin
Oct 2, 2013
51,092
844
108
That works, but it's a lot to have to do.
Tartarus
Feb 20, 2014
17,446
26
48
Depends, my router is in the living room and easily reachable, the pin to remove SIM card from iPhone is on my keychain so even that's a piece of cake to do.
Depending on how desperate you are to disconnect your iPhone from internet nothing can stop you doing those things a suggested
Ledsteplin
Oct 2, 2013
51,092
844
108
I would have to be extremely desperate to do all that.
pkcable
Q&A Team Leader, VR Expert
Jun 16, 2009
5,827
28
This is the surest way to do it, you MIGHT be able to do it quick enough via Led's way, BUT Tart's way you will get it for sure. :)
Mac Guy
1,910
f you turn it off in airplane mode, it'll be in airplane mode when you cut it back on.
I think this is the only thing that addresses the OP's concern- WhatsApp telling the sender of messages that the OP has received them. Simple, effective.
If What'sApp is running in the background, the sender will know the messages have been received as soon as the phone is turned on, unless using Control Center very quickly will beat WhatsApp. Like unplugging the computer because you accidentally sent an email that you meant to delete.
I turn off Control Center for the Lock Screen to prevent it from being cloaked from Find My iPhone should it fall into the wrong hands.
Ledsteplin
Oct 2, 2013
51,092
844
108
No one can access your phone from the control center on lock screen.
Mohammadreza
