Is there a specific iPad Pro 12.9” model # that is compatible with Verizon’s Network?
ZOFOURTWENTY
721
9
Is there a specific model # that is compatible with Verizon Network? I want one for Verizon and saw a good deal on Amazon for $955 for the 256GB but wanna make sure it can be used on Verizon
60,412
882
iPad Pro 12.9” for Verizon
If you haven’t purchased it yet, buy one from a nearby Apple Store. It will have an embedded Apple SIM as well as a SIM slot for you to insert a SIM from a carrier.
Jude526
Trusted Member
Jan 15, 2017
2,413
15
Re: iPad Pro 12.9” for Verizon
They can assist you. You can also look on VERIZON to see what they have. Might have promotions on them as well
Jude526
Trusted Member
Jan 15, 2017
2,413
15
When at Apple store tell them you are a Verizon customer and they will make sure you get the correct ipad or you can go to Verizon as I had suggested prior. I got mine from Verizon
Jude526
Trusted Member
Jan 15, 2017
2,413
15
Mine is on data plan. Data built into it. Not wifi. YOU can USE a wifi on any network but if you want a data plan attached to your ipad it has to be for your specific carrier.
Raptor007
Trusted Member
Jul 3, 2010
1,309
7
When getting an iPad or even an iPhone its always better to go to the Apple Store if you have one near you, less hassle, less problems and with the iPad they will get you the right one out the first time without worry.
Mohammadreza
