Am I correct in my thinking that the Siri addon AsssitantExtensions does not work properly with the latest 5.1.1 JB ?
I experience a hanging IPhone 4S when I try to send an SMS using Siri.
Disabling AE resolves the issue.
Other stuff in Siri works - seems to be just the SMS sending causing the hang. I can dictate the message and everything is fine up to the point of sending the message and then it hangs.
I cannot replicated *every* time I try to send an SMS with AE enabled - just sometimes and it seems to be the first message I try to send . After a restart, it *usually* works ok .
Thing is, I find AE very useful and I am wondering if there is some fix for this problem which seems to be a known issue.
-keevill-
-keevill-
