I'm teetering on the edge....coming to the dark side - Help convince me!
jianrong
349
My last Nokia phone was N8. Then after I hop into iPhone 4. That when I realise the usage of web browsing, games so and so. Then I switch to Android with Note 2. Bigger screen and open concept. Then into Note 4 but actually wanted iPhone 6 Plus it's so hard on stock so I get Note 4 on launch. Surprisingly I sold off Note 4 and grab a 6 Plus on Jan 2015. Until March 2016 traded in for S7 Edge. Awesome S7 Edge, open Android, pretty display, good battery life..... But when iPhone 7 Plus I got attracted to it again. Never thought I would com back. As my contract has ended too. After I sold off S7 Edge. My iPhone 7 Plus cost way lesser for TOP up.
Nogitsune Micah
201
Come on and join the dark side. Leaving android was ironically a freeing decision. I use a program called copytrans to move files such as ringtones to my phone.
kiwimo
Nov 1, 2016
4
If you download from the app store "Ringtones for iPhone Free" (it has a blue icon with a white speaker) you can use this to create custom notification sounds and ringtones. There are other apps, this is what I use and it works flawlessly. You can import a song from your play list or use one of the many in their catalog. You still have to sync it through iTunes but the app has a little video to show you how to make and how to sync-it's really simple. All you have to do is choose a song, choose what 30sec segment of the song you want, create the ringtone(in the app), connect your phone to PC, save the song to your computer then sync via iTunes. Hope this helps.
Mohammadreza
