iCloud and Match Problems
Vapor85
Nov 17, 2011
Been searching for a solution for a while but cannot seem to find a solid answer. Can someone explain to me why there is a Cloud only on some of the songs (most) in my iTunes library and what do I need to do in order for them to all have the cloud?
Secondly, the past few weeks sometimes when I try to add a song to my iphone it doesn't add and it shows up in the playlist but the song is all gray.
Lastly, how can I use the match feature and still add playlists that I want?
Thanks in advance for any help.
verwon
645
42
Under store, you can select update iTunes match.
Set the playlists up in iTunes, they'll show up on your phone, with the option to download all songs.
Sent from my iOS ecosystem!
Jethro7
