I need help for my Iphone3g
iTwins
Dec 20, 2008
I have iphone3g locked on ATT, i used Usim to work with my carrier here in my country....my problem is icant copy all contact from sim to my iphone...
I go to setting,cmail,contact,calndarsthen click import SIM contacts...but contact not copied.
Thanks in advance
Regards
amit85
Oct 6, 2008
35
i had the same problem. You cannot get your contacts as long as usim is inside the phone. Only 2 methods.
1. Take out usim, copy all contacts and then manually enter them in iphone.
2. This is easier way. If you have those contacts synchronized in MS Outlook in your Laptop, then synchronize iphone with itunes and there transfer all contacts from outlook to iphone. I did this way to get all contacts on iphone.
Do let me konw if i helped.
Remona94B9
