I have changed my wifi modem, now i am facing connectivity problem. How can I fix it?
I
iMore Question
I have changed my wi fi modem, now i am facing connectivity problem.
I have changed my wi fi modem. I am facing problem of connectivity. I have not much know-lag of computer. The same problem I am facing with my iphone 4 S. I need some one to guide me or tell where i may go to see Apple customer care.
Bigeric23
3,630
Re: I have changed my wi fi modem, now i am facing connectivity problem.
Did you purchase a Apple router? If not, what type of router/modem do you have?
Ledsteplin
Oct 2, 2013
51,136
872
108
Your modem has the same problem as your iPhone 4s? Did you try to reboot the modem? Unplug it for about 1 minute. Then plug it back in and wait about 5 or 10 minutes and see if it works better. Check your connections as well. Do a hard reset on your phone.
Hold the top power/sleep button and the home button at the same time until the Apple logo appears, then release.
It won't help your modem, but it might your phone.
Yuan
