How does Dark Mode / Night Shift work?
The_Prodigy1982
276
I never really tried Dark Mode/Night Shift, even though I'm running the latest macOS since it was released... so this might sound silly to some of you.
Anyway, I'm just curious how does Dark Mode work exactly?
• Will it change ALL the colors, or are the darker colors only reserved for the actual UI's of the system (as well as the supporting apps).
What I mean by this, when doing some graphics design... will colors that you work with also be affected, or will Dark Mode purely change the UI itself?
• And is it possible to configure Dark Mode, so that it automatically switches at the same moment that the Dynamic Desktop wallpaper changes?
I'm having the same questions about Night Shift...
I really like the Light/Dark shifts, but I would only use it if it doesn't screw up the colors during graphics design.
Spencerdl
Apple Watch Champion
Jan 10, 2013
41,139
207
63
Just turn it on and see if it does or doesn't do what you want it to do. You can always turn the toggle switch on or off.
Mohammadreza
