Step 1: Add the following repo in Cydia: http://repo.bingner.com
Step 2: Install ?SAM? and ?SAMPrefs? from this repo.
Step 3: Now we?re going to revert to a stock lockdownd for SAM to function. To do so, download RedSn0w 0.9.6b6 from our downloads section, launch RedSn0w and select the ?Deactivate? option. This will remove the normal patches made to lockdownd and let SAM take over.
Step 4: Go to Settings > SAM, then click ?De-Activate iPhone?.
Step 5: Make sure iTunes is on, plug your iPhone and let iTunes activate your iPhone. If iTunes says ?Invalid SIM?, you will need to manually select a carrier under Seetings > Carrier.
At this point, you may unlock using UltraSn0w if necessary (see our UltraSn0w tutorial here).
This fix will allow you to get the full benefit of push applications while increasing your battery life substantially.
[Sbingner via Dev Team]
For More information and help go to Hot to Fix: iPhone Battery Drain After Jailbreaking and Unlocking ? Iphone Unlock Jailbreak Downloads Activate Hack Tools Application Games - Iphone Downloads For You
