Help stuck in pwned DFU mode
starstylers67
Oct 2, 2011
10
I have an iphone 4 that I was trying to restore (4.3.3) without updating to 4.3.5, so I did all the steps like deleting the apple lines from the host files and finally as a last step I used Tinyumbrella to restore.
Everything was going fine then I got an error, and the solution seemed to be to try it again by having the phone in DFU mode. I used a program called iReb to put it in DFU mode and tried it again and this time I kept getting error 1601.
However I cannot get the phone out of the DFU mode. Can anyone help me? Its been about 2 days that I have been trying to fix it with no solution
starstylers67
Oct 2, 2011
10
tinyumbrella says in the logs that the dfu device is connected, however the only option I see is fixrecovery option and that does nothing
I also downloaded fixrecovery from tinyumbrella website, and that didnt work either. all the stuff ran but at the end it was still in dfu mode.
robes1
256
12
Do a hat reset. I'm guessing you've already tried that though. If you have then the only option may be to restore and update through iTunes which may leave you on 5.0. Sorry I couldn't be of more assistance.
Peligro911
5,878
136
1601 make sure all your options in tu are checked to make sure it's acting like the apple server and that are blobs are there and then Try to shift restore 4.3.3
starstylers67
Oct 2, 2011
10
at this point i wouldnt even care if it upgrades to 5.0 cuz there will prob be an untethered for it soon, but i dont even think I can do that. When i do the normal apple restore i get error 3194
alupo790
Jan 11, 2011
34
i was updating yesterday and got the 3194 error, go into tiny umbrella and uncheck the "set hosts to cydia on exit" then try to upgrade again, worked for me
No members online now.
Jethro7
