HELP! No sound from loudspeaker, even after replacing speaker and 3.5mm dock (with reset)
jonib1988
Apr 9, 2015
IPHONE 5
Hi,
After suffering "the" charge port problem, in that the contacts wouldn't make a charge without moving the cable, I replaced the charge port connector. Immediately after replacing the charge port my loudspeaker stopped working - sound still worked through earphones.
Due to the forums reporting faulty with the loud speaker generally, I purchased a new loudspeaker but this repair was unsuccessful too.
Going back to my initial repair I thought I may have a defect on the 3.5mm jack that came with the new charge port, so I purchased another charge port and installed this with the new speaker. Still not sound from the loudspeaker.
I have now carried out both a soft and hard reset, checked the sound with Bluetooth and wifi off, but still no luck.
I really want to resolve this problem, rather than buying a new phone. Any advice would be appreciated
kch50428
21,025
305
I'm tech savvy - but would not work on an iPhone... I'd go to an Apple Authorized service provider...
iEd
Banned
Jun 13, 2012
3,402
IPHONE 5
Hi,
Get a new phone.
Sent from my iPhone 6 Plus using Tapatalk
HankAZ
Banned
Jul 26, 2012
6,092
IPHONE 5
Hi,
Exactly what is "the" charge port problem? Are you saying that's really a "thing"? If repositioning the cable caused the phone to charge/not charge, how did you eliminate the cable as the problem before going all Frankenstein on your phone?
Just another reason to purchase AC+ and leave the fixing to Apple.
jonib1988
Apr 9, 2015
Hi,
The charge port wouldn't work with any cable and it was due to worn contacts within the port. Changing the charge port is a common job and after changing this the phone charged fine.
To confirm, the charging of the phone is no longer a problem and the cables that wouldn't work before are now fine. A process of elimination was followed before dismantling the phone.
Walkyier
Apr 14, 2016
Hey I had the same problem after replacing the charge port. I put it back together and had no sound from my speaker. Took it apart and saw I had the cellular data cable laid out across one of the connection pads for the speaker. Has to be in a very specific spot for the speaker to make the connection. Pushed it off to the side so it was still connected to the logic board. Laid the speaker out on the pads, put it back together and now it all works. Simple to check. Hope it helps anyone with the same problem. Cheers!
ELLIEYES
Jan 29, 2019
3 years later and you are receiving love from a stranger - me!
THANK YOU! Tried to fix my phone, but it seemed that everything I wrecked something more ha. This was the final thing that needed to be fixed. :) Thank you so much!
geas34
