Help-My volume button stuck
gal432
Jan 24, 2009
hello
i have a Iphone 16GB 2g.
i dropped the iphone and now the volume button is stuck.
when i wont to reinforce the volume he down the volume alone.
there is a software that can neutralize the button volume or a way to fix the problem?
thanks
gal
jamesus
TiPb Forum Staff
Jul 10, 2008
1,840
11
Try Settings > Sounds and move the slider to the volume you want.
If that doesn't work, you might have to take it to the Apple store. As far as I know, there is no software that overrides the volume button besides trying the method above.
Tricia_TD
