Has anyone with an XS Max had problems with the ringer working sporadically after updating to iOS 13.1?
I
iMore Question
Since my surprise update to IOS 13.1, my ringer has been having issues working sporadically. If I go a reboot, it will work for a while. Everything is as it should be. I ay have to go back to 13.0. I don't know what's going on. Do not disturb is off, ringer volume is on. and the ringer switch is on. Thoughts? Suggestions?
58,451
317
83
Re: IOS 13.1 Update - XS Max Ringer Issues
It’s beta and everyone’s experience with it will be different. That’s just how it is with beta software. With that being said, you can try resetting all settings to see if that helps.
gamo62
Oct 29, 2014
I tried that. Everything worked fine for a shoet while. Reset to 12.4.1, and it worked great. 13.0 worked fine with no ringer issues. But with that sneaky 13.1 update, that was the culprit. I tried downloading the IOS 13 beta 8, but it was no where to be found. And then lo and behold, 13.1. WTH was that all about! I guess I'll wait until Beta 2.
Spencerdl
Apple Watch Champion
Jan 10, 2013
41,001
125
63
Welcome to iMore. Yeah, I'm also having issues and trying to be patient while I wait on iOS13.1 Dev Beta 2.
gamo62
Oct 29, 2014
Updated to 13.1 beta 2 today. Rebooted and the ringer worked! For awhile. Now it's back to not working. I have an appointment at Apple tomorrow. I'm hoping that it isn't a hardware issue. It is under warranty until the end of this month. This is odd I will say.
Rob Phillips
Champion
May 1, 2012
13,761
Considering it’s still under warranty they’ll likely perform a factory reset and then replace your iPhone if it keeps happening.
Getting a new iPhone weeks before your warranty is up isn’t a bad thing in my eyes!
Spencerdl
Jan 10, 2013
41,001
125
63
Did the ringer issue start with 13.1 beta 2 or has this been happening since you had your iPhone?
jamesteve463
