I updated to is 7.0 on my series 5 and it’s certainly draining a lot faster than it did on the last is 6.x.
Has anyone else noticed?
My Watch battery life is about the same as it was prior to upgrading to watchOS 7.
To anyone with a series 4 or 5 Watch, can you adjust the brightness of the always on display?
Since the series 6 will have brighter AoD, I am almost certain that I’ll dim the brightness to save up more time and to not be distracted by the screen while driving with short sleeves.
In settings on the Apple Watch 5, you can go to Settings - Display and Brightness and adjust the brightness with a slider between two sun symbols.
I gather that’s the brightness of the screen when in use.
Is there a separate slider for AoD?
It seems to work for me. I have AoD.
Thanks for your replies.
I guess I’ll figure it out once my S6 arrives.
I have the brightness set fairly high and AOD has been enabled from day one and I can easily go an entire day and still have about 45 - 50% battery life remaining when I go to bed.
Mine is draining much faster as well. Before the update, I would hardly ever drop below 35% with my 16 hour days. Now 5 hours into my day, I'm sitting at 56%.
