iPhone?s with iOS7 have little dots in the top left corner of the screen to displaying signal strength.
How many dots do you have on your cell phone and what do they represent? The amount of dots will give a general idea of your chances
on making a phone call. With no industry standards set as to what each dot represents, the variables are numerous. You are never quite sure
of your exact signal strength or just how close you are to the next level.
The signal reading in the images in this guide represents a low signal strength, e.g. the lower the number?closer to zero?the stronger the signal.
-75 would be significantly better than -113 as depicted in the images.
I will show you how to change, step by step, to a more accurate method of measuring signal strength. We are going to use decibels (dB)
to measure in units of power and intensity.
If you don?t like the more accurate method of measurement, just a swipe or tap of your finger across the dB signal and your get your dots back!
