I can not remember code into my the restrictions!!!! I need to allow a cpl things in there lease anyone. Ive even tried apple support no luck. Thank you in adavance. Andrea
Thank you guess ill do that was tring to avoid that.
I cant find a wsy to reset without having to have a computer or the reset setting thats locked
I cant do any of that. The phone comes back as it was.
You can't do any of what? You do not need your restrictions passcode to reset your device, you will need the lockscreen passcode, if one was set. If you do not even know your lockscreen passcode then something is suspicious. Anyway, there isn't a way to bypass the restrictions passcode, except by resetting the device. Period.
