Fast Charge with Apple AC adapter and cable (double sound)
iLive an iLife
Trusted Member
Feb 27, 2011
1,087
32
Hi All - Is anyone using fast charge with Apple accessories? Whenever I plug in my iPhone X it makes the charging sound twice in a row. It doesn’t do that with the wireless charging or a normal lightning charger. Wanted to see if this was normal or if I should look into exchanging the cable/adapter?
58,154
228
63
Is use an iPad charging clock , but I don’t get the double sound you mentioned.
iLive an iLife
Trusted Member
Feb 27, 2011
1,087
32
Thanks for the response. I also doing get it when I use the standard lightning charger. I need someone to verify what happens when they use quick charge :)
jsntrenkler
Trusted Member
Mar 9, 2010
2,782
55
I use usb C quickcharge with my iPad Pro. I just plugged in my X. Only made the sound once. I can confirm that there is no double charging sound with quickcharge.
jsntrenkler
Trusted Member
Mar 9, 2010
2,782
55
I did have this problem once before with my 7 plus. It turned out that there was a tiny piece of lint in my charging port. Once removed it went back to normal.
iLive an iLife
Trusted Member
Feb 27, 2011
1,087
32
Thanks for confirming! My standard Apple charger works without a problem, so I’m thinking it’s probably the cable or adapter. I just got them on Friday and this was my first time using them. I’ll be near an Apple store next weekend - I’ll swap them out then. Thanks again!
oben02
Nov 24, 2017
Hi, I have the double sound but only when I plug the iPhone (X) when lock. If I plug when I’m using it I have only one sound
felloffthetruck
iPhone 7 Plus Champion
Champion
Oct 15, 2014
2,305
I have the Apple 29W USB-C and the Apple USB-C to lightning 2m cable and it's doing this same exact thing.
I only used this setup twice and quit using it. Something is just not right and I don't want to damage my new iPhone X.
ZOFOURTWENTY
Jan 11, 2011
721
9
This happens to my X when I use my 61W USB-C power brick. I’m not sure if it happens while iPhone is locked or not. I can confirm this doesn’t happen when I use my 10W USB to Lightning charger. Thought it was weird but haven’t given it a second thought till I read this. Just thought it was part of USB-C charging.
oben02
Nov 24, 2017
I use the 61W USB-C power brick too. I called apple today and they will investigate « this issue »
ZOFOURTWENTY
Jan 11, 2011
721
9
I have a Qualcomm USB-C quick charge car charger and have never used it, wonder if it’s the same double sound there. Haven’t been in the car long enough to warrant plugging in since battery life has been awesome for me
CA808
Dec 28, 2017
Actually, I can confirm that I also get the two notification sounds when connecting my iPhone X to the Apple 29W adapter using the Apple USB-C to Lightning cable. I believe this is normal behavior.
