Excessive battery drain & missing stats, what can I do?
I
iMore Question
I have an iPhone 5S which is on iOS 9.2.1. The battery drains extremely fast while the phone is not is use, screen locked, the drain is much lesser during normal usage. Also, the battery stats page keeps saying that the battery stats will occur after using the phone for a few minutes all the time. The phone also says that this iPhone has been plugged in since last charge, but the time counters since the last full charge are fine.
I had the same issue on iOS 9.2. I tried a hard reset, and a clean iTunes restore, I am out of ideas, what do i do?
Rob Phillips
Champion
May 1, 2012
13,760
5
Re: Excessive battery drain & missing stats
Welcome to iMore! If you've done a clean install through iTunes and the problem persists I'm inclined to think it's hardware related. It could just be your battery itself which makes sense considering the excessive draining. Apple's lithium batteries are designed to retain 80% of original capacity for 500 full charge cycles. After that, it's normal to start experiencing decreased battery life.
Ledsteplin
Oct 2, 2013
51,092
846
108
The battery is wearing out. It happens. My old iPhone 5 battery is shot. Very soon, you will either need to get a new battery or a new phone.
Mohammadreza
