Welcome to the all-new iMore Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
I wouldn’t use Lossless on Cellular streaming, because it uses a lot of data, like a lot more (from memory 3000Kbps, instead of 256Kbps).
Personally, I can usually hear a difference on Dolby Atmos songs, but I barely distinguish a lossless track from a lossy one. There are exceptions to both of them, but they are that, exceptions.
Would it matter if you have an unlimited data plan?
Depends on your data plan structure.
If you have a unlimited data plan that does not throttle after a certain allotment, I would say no… if you always have good 3G, 4G or 5G service (by good, I expect a constant minimum of 15Mbps downstream speeds).
If you have an unlimited plan like me that throttles after X GB (I have 15GiB), then I would totally change it. Does not matter if you have a good service level or not.
If you have unlimited data, you should be fine. It's not like you'll be listening to music non stop. And many songs are not even lossless songs. If a song is both Dolby Atmos and Lossless, it defaults to Dolby Atmos.
I’m surprised at how many songs, especially older songs, are lossless. I’ve not checked all of my playlists, but the ones I listen to regularly contains songs that are lossless.
Recently when playing music through my paired HomePods I’ve noticed songs having quite an echo effect. Does that come from the Dolby Atmos feature being turned on?
Lossless and Dolby are separate settings. It's unfortunately either/or. While listening to music it will tell you what it is.What’s everyone’s opinion on Dolby Atmos and the available audio quality settings? I have Dolby Atmos turned on and these are my current settings. Is there a better configuration of settings or any reason I should change something?
//uploads.tapatalk-cdn.com/20210709/946d8fcea937dc41175aadbd8dd85c0a.jpg
Same here……
For myself personally, I've chosen high quality lossless over Dolby.
